Originally Posted by RCShocker
Awesome looking build Shaun. Everything looks so clean and well laid out. No need to hold back, huh? You build them soooooo fast. Do you have anytime to enjoy it?
Great to let everyone know how much fun crawling is. Especially after being used to the ballistic missile's you usually build. I cant believe how addicting crawling is. We had 23 guys at our last $2 Buy In Comp.
And yeah, I usually run thru 3 courses and/or 3 hours on the rocks without touching my packs. Of course I'm not running the whole time. But my packs are right there threw the whole comp. One less thing that needs attention, so thats a plus.
How are the Traxxas shafts holding up?
Doug
Thanks for the kind words Doug, Crawling is really FUN,
it’s SLOW but I'm amazed every time I go out what this thing can do and how deferentially it react’s to smallest of changes.. Just changing foams for the surroundings makes all the difference, it’s been a blast..
As for the Jato shafts, I'm replacing them on an average of once every three outings
I'm not sure if that good or bad, but I do know I'm not hurting my diffs or trans and I’ve got down, I can change out a drive shaft in under 2 minutes..
Have a great on Sir
Originally Posted by traxxasrevony
nice set up ihave about the same thing only without a dig droop setup and the 7t motor.
those losi rock claws arethe best tires i have found so far and ive tried lots of tires. im running maxx shocks with 20 wt oil and super soft springs my ride hight is about 2 and a half inches and its perfect. i would get a set of mip c shafts in place of the jatos there super strong. if you havent already join www.rccrawler.com im on there and my name is ax10ny
Thanks you traxasrevony and COOL we have the same build
(basically) Yep I'm a member on the forum too.. Same name (TDC57)..
I checkout your bad boy, looks real good… I’ve been experimenting with different foam compounds and tire weights at the moment, I’ve quite happy with my badlands for most situation, but the rock clawers do provide a better side grip (IMOP)
. What foams are you running (?)..
Have a great one Sir
