lutach
lutach's Avatar
09.07.2008, 10:36 AM
Originally Posted by e-mikey View Post
Found it.
When I soldered it, I let TOOOO much solder back up into the motor wire, causing it to become brittle and snap. I'm not sure if I can de-solder it, so I might just heat it up an bend it into it's final position.
Any ideas? And is my motor shot, it still works.
Send it back to Neu and get it fixed. The temps your motor saw might've done more damage then you think. The enemal probably melted off and that can cause a lot of problems.
