09.07.2008, 08:01 PM
Nice...I just bought a crt.5 myself and am waiting to pick it up tomorrow...With those paddle tires you will kick up some serious rooster tails.......From your pics, is that the 40mm ext. chassis Mike sells?
I like the body.........and the keg in the background...even the brand!
WELCOME TO THE FORUMS!
chip cross
09.07.2008, 08:20 PM
Yes, its the 40mm ext chassis from RCM, very good quality chassis, I frikin love it. The paddles are for the sand bar at the river, I plan to do some brushless slash smoking with this thing. I all so have some bowties and road tires for this thing. About the keg, I am on a Coors kick for some reason.
09.07.2008, 08:26 PM
I also have a yearning for Coors light... which is my drink of choice...
09.07.2008, 08:21 PM
Looks good Chip, I like the paddle tires and the bug body, definately unique! Only thing I would suggest is a Rcm heatsinl/clamp for the 9l. Helps knock a few deg off the motor and will keep it together after a few hard landings. Can't wait to see this in person!
chip cross
09.07.2008, 08:25 PM
Thanks for the info, do you know of a good fan for the esc? I hope you guys made it thru the storm ok.
09.07.2008, 08:30 PM
The novak 25mm fans work well for the MM, just use an 1/4 spacer on each screw to give the fan some room to mave air.
Did you do ok in the storm?
chip cross
09.07.2008, 08:33 PM
No, my pickup has alot of body damage.
09.07.2008, 10:48 PM
Good thing you know a guy who owns a body shop
chip cross
09.08.2008, 12:45 AM
Yep, it will need an all over paint job. I need to get a roll pan and some Caddy door handles before you start on it.
