Is the center drive from a tower terror? Looks very similar if it is not...
I really like this idea, cant wait to see the finished results. The tlt axle should be fine, but you may want to invest in some straight axle adapters, and the one piece axles.
Thanks linc, the CD is actually the .5's one turned on its side. Im going to run mikes motor mount vertical and hopefully run two 3s packs in parallel. I need to order some carbon and make some templates going so I can get this build done sooner..
