JaySki
JaySki's Avatar
09.08.2008, 02:35 PM
I don't buy ANY materials out of China, and most of my parts are direct from the manufacturer.
So no, this isn't the case.
We are investigating right now -- but the failure rates are not all that high (regardless of the noise on the boards...)
We have also seen that most people don't have a problem, and then others toast 3, 4 or 5 controllers in a row. We are trying to figure out WHY some people toast many controllers, and others are just fine. It might be broken servos (we have seen broken digital servos damage switching BECs) or it could be bad motors, we just aren't sure yet.
Patrick
I am running a brand new NEU1515 1.5D, Stock Servos. My last MMM ran FLAWLESSLY with a UBEC, until I changed setting in Castle Link. Up until now, I left it all at defualts.. even the LVC.
Yesterday, I changed the LVC to 12.8, Punch Control to 70% and modified the throttle curve a bit. 10 minutes later it jerked a bit at slower speeds and died. Motor never hit 100 and the MMM was still relatively cool. Didn't even smell like anything burnt. No lights nothing. Disconnected batts and threw them on the charger, tried another set of Batts and still nothing. Only running 4S.
Prior to the changes in Castle link.. I ran the snot out of it the weekend prior. Had a few runs that hit 55MPH with no real heat issues and no problems.
jayjay283
jayjay283's Avatar
09.08.2008, 02:48 PM
Did you try putting it back to auto lvc and testing it ? Heard they were having some issues with manual lvc settings
phatmonk
RC carbon junkie
phatmonk's Avatar
09.08.2008, 04:16 PM
So is there a issue with the LVC manual setting?I havent taken any chances changing mine to manual or custom.I have 2 MMM V2s and is 3s and the other is 4s.Both work flawlessly
TruckBasher
TruckBasher's Avatar
09.08.2008, 08:47 PM
Now that you mentioned it the first few packs on my modded V2 run fine until I change the LVC to a custom 1 and change the brake amount...after that I was able to run it for 15-20mins then it just stop working after serious cogging in forward and reverse....
Not sure if it make sense...not sure how the software affected the HW ...
E-Slayer direct drive to diff
JaySki
JaySki's Avatar
09.09.2008, 09:22 AM
That is seeming to be the trend....
jhautz
jhautz's Avatar
09.09.2008, 12:30 PM
Weird thing I was just thinking about when I read this.
I recently had 2 MMMs die on me. A V1 and a V2. I had one of the first 50 or so V2 MMMs that were shipped with the 1.18 software on it. Apparenty it had some sort of LVC program error that didnt cut off the LVC unless you were at less than 1/3 throttle. I read about it on the CC website. They said there were only 50 or so that got out with that version software and the rest were shipped with 1.19. When I read this I checked and found 1.18 on mine so I updated it to 1.19 and the next time I ran it, it died. It only had one race day on it but it had been working perfectly up to that point, and I never got even close to the LVC so I didnt see any 1.18 problem. Didnt really think about it untill jsut now, but I wonder if the software had anything to do with it?
I also had a V1 that was running 1.17 and had close to 20 hours of run time on it and was still working well. I updated it to 1.19 at the same time and it died the next time I ran it also.
I have one V1 left. It still has 1.17 software on it. I am not going to touch it. I has a good 10-12 hours of runtime on it and its still going. I dont know if the software had anything to do with it, but at this point I'm not going to introduce it as a variable. Its working as is. I'm leaving it and I guess I'll se what happens.
to make it...
or break it...
Silent...But Deadly
pasan
I <3 RC
pasan's Avatar
11.15.2008, 06:29 AM
I just saw today that mine too is a 1.18, and I have run it through at least 10 packs on 6S without any problems at all. I upgraded to 1.20, and honestly I'm a bit scared to run it now :(
