I used a piece of kydex, and drilled 2 holes so that it would bolt in where the evx goes. Then I used some double stick tape to hold the MMM on. Since the chassis has a square of foam under the evx, I cut a section out so that I could put a zip tie under the kydex and wrap it over the mm to hold it in even better. My MMM does not budge, I can lift the truck up by the esc...
You could try a 3m double-sided pad, I've used those for Rx and ESC mounting before and they work really well until you burry the entire RC underwater, then they start to loosen up :p
That's crazy Hoov. Looks like the mounting plate did it's job well, though. Great job on the construction and I may do the same thing.
I'm using one of these:
There are actually 2 screw holes in the chassis where the inside screw went for the EVX, so I have a button head on the outside edge and a flat topped screw on the inside of one of the adjustment slots. Stays put rather well with the MM and should handle the v2.2 once it's here.
Hope mine doesn't melt down. :(
That happen with 4 or 6S, Hoovartid?
I use this stuff (Parma Pro Servo Tape) http://www.amainhobbies.com/product_...oducts_id/6183
for mounting escs and receivers. It holds really tight on both plastic and bare metal and unlike regular double-sided tape it is very easy and clean to remove. It comes off just like the stretchy glue stuff that holds removable ad cards in magazine inserts and on covers.
“Everyone has a right to be stupid; some people just abuse the privilege.”
