tc3_racer_001
tc3_racer_001's Avatar
09.11.2008, 04:27 AM
my friend has a razor mini chopper and in 2 weeks we are modding it - 2x 4s 4800 lipo (in parallel) a mamba monster a servo tester for throttle (if that works!) and a motor which should work... a qusetion though - generally - is there any way that th monster max wont work - like is there a difference between the MMM and a scooter esc (apart from the controlling thing) like will we damage it in any way? the lipos should be fine, plenty of power, more than the lead acids currently in there....
shoud be fun - for the cost of a motor....
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.11.2008, 04:57 AM
Hey man, if you can swing it financially, use this motor:
http://www.robotmarketplace.com/prod...G-S28-150.html
It puts out 3HP at 24V but weighs less than 4 lbs. The price reflects the CNC aluminum can and the use of Neodymium magnets. My BattleBots team used them for a spinner-type robot back in high school. These motors rock! The downside- your batteries will need to supply 100A to realise the 3HP rating. I suppose you could mount a 3F car audio capacitor in there to help with acceleration....
tc3_racer_001
09.11.2008, 05:59 AM
jeez. anyone know where to get a 500-1000W dc motor from? suitable for something liek this? what would happen if u tried to use an 36mm xl motor? would it have to be geared down so far or what? i might try it just out of curosity...
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
09.11.2008, 09:59 AM
1. Way too high kv
2. Shaft WILL break
3. You'd fry it b4 the shaft could break
4. Duh
09.11.2008, 09:58 AM
How I'd love that motor.
It spends at 6k rpm though, so I'd need this too.
http://www.robotmarketplace.com/products/TW-TWM3M.html
And that I most definitely can't afford!
What's_nitro?
09.11.2008, 10:23 PM
3HP @ 6K is too fast???!!??
You could go the cheap route and use a couple 750 sized boat motors. A significant gear reduction would be necessary, but I'm pretty sure planetary gear boxes are available.
Have you seen these? ScooterSupport.com They have 36/48V 1000W models; 4" diameter, 6" long, 11 lbs. , ~$160.
09.11.2008, 11:43 PM
That would be nice. I'm tryin to go really easy on the wallet though. Over the last 2 months ive spent about $2000 on rc's and when you're 15 that's a bit too much. :)
