JaySki
JaySki's Avatar
09.11.2008, 02:25 PM
Originally Posted by TexasSP View Post
You are at the top line of spec only assuming adequate airflow. You must also account not just for rated current but stall current, spikes, and so forth.
The motor is rated at 120 amp and the controller at 120 amp with air greater than 500 lfm. Pretty tight when you look at it. Then factor in that with 0-200 lfm you get 70 amps, and 200-500 lfm you get 110 amps, you can see where the problem is.
Running the KV as high as possible is not the best way to get speed in a monster truck, you can't apply 10th scale or 18th scale formula's in a monster truck and/or 8th scale world. You are much better off to get a lower KV motor and gear down to attain the speeds you want. Then there is the fact the having a high speed setup on anything but the street changes the dynamics drastically.
Where I agree with where you are coming from.. And in in all honesty, running the 15.d on 6S is not on my list of normal activities. Brand new batts, Nearly new MMM, not abusive AT ALL. And actually never got past, say half throttle, and there is no way to even punch the throttle on 6S with the 1.5D and geared where I was... Current Draw SHOULDN'T have been real issue.. Setting all that aside...
Where did you find the MMM is rated at 120A? I agree running the 1.5D on 6S is on nearing the upper limits, but it still isn't over. If I was drawing too much current, the batts would have heated up.. or givin an indication of sucking too much out.
Add in the fact the truck literally flamed as the truck was rolling at a walking pace.. makes me question...
Additionally, CC saying TrueRC batts are the cause.. Wouldn't there be issues with the Motor or performance beofre the whole damn thing torches?
