SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.12.2008, 12:50 AM
Yeah, I notice this as well with my MM. I was looking around at the neu website and they seem to recommend 13 khz for their motors. I wonder if that is what the MMM is set at because castle will be comboing the MMM with their version neus. I would like to know for sure because there seems to be wide range of motors that people are using and each one may require a different drive frequency to run most efficiently depending on if its two pole, four pole, slotted, slottless, wye wound, delta wound, high turn, low turn or what not.
Area 52 Ranch Raceway
T.R.C.R.
