DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.12.2008, 05:44 AM
Originally Posted by kevin23 View Post
going up in rear diff will stop the rear from coming out under acceleration,will also stop any "fishtailing" you may have coming out of turns on power.
moving the rear camber link in the tower down to 4 hole with help with the rear bite also.
Thicker rear diff has less steering in the middle of the turn and more foward traction. The standard kit was running the rear camber link at 4-B and most of the setups on Losi site uses 4-B, so might give that a try
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
