rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
09.14.2008, 11:39 AM
Now you need to remove the flywheel off the engine.
The kit comes with an adapter that puts the whole clutch assembly onto a 5mm shaft of a BL Motor...
You can then assemble the motor mount. This thing lays right in where the Nitro Engine mount set. It also gives you full adjustability for most popular BL Motors up to the length of and XL (what I am using)
It also gives you full adjustability for perfect mesh setting
Once you have that set...you are home free
Install the ESC Mount
Install the battery Tray and straps
You are pretty much done with the conversion...
Bought my Wife a Rock Garden :027:
