Backfire
09.17.2008, 08:55 AM
The most important piece of your track setup is the tires. Even a perfect chassis setup can feel like junk if you do not have the proper tires under it. I would check with others at the track to find out what works best before fighting with smaller adjustments. You mentioned that your fronts are a bit worn, how about the rears? There are several tread patters that work pretty well on many conditions.
The ride height adjustment should be made from where the vehicle settles on its own after dropping the vehicle from several inches of the ground. You also need to take the measurement with the vehicle ready to go run. A measurement with out the battery would not be very useful!
Also, the heavy center diff fluid is good for our brushless setups for better efficiency, but it is not necessarily the best for chassis setup. The heavier center diff will prevent dumping power to the front diff and keep a closer balance front to rear. However, this has made the rear of my car a bit nervous at the same time. With a normal center diff setup, there is less power going to the rear, and less chance of breaking the rear tires loose. If you can keep control of the car, you will probably accelerate harder, but it will take some more effort to keep the rear from coming out under acceleration.
Bryan
jhautz
jhautz's Avatar
09.17.2008, 11:25 AM
http://www.teamxray.com/teamxray/sho...p?file_id=4461
Here is an awesome setup guide for buggy and truggy. Very useful when trying to solve a handling problem.
Its published by Xray but the principles apply to any buggy of truggy.
And I 100% agree with backfire. Without the right tires, you are just chasing your tail. Tires are the first and most importenat piece of any track setup.
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
09.17.2008, 11:36 AM
To answer the dif oils questions:
EFFECTS OF DIFFERENTIAL OIL REPLACEMENTFront
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners
Thicker
• Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too much power and sometime “cook” the oil in the center differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle
Rear
Thinner
• Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
to make it...
or break it...
Silent...But Deadly
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.18.2008, 12:46 AM
Sweet, thanks for the link
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
