Mozzy
Mozzy's Avatar
09.20.2008, 11:09 PM
Well, I'm off to the park in a few minutes. As soon as my mates lipo charges.
I'll let you know what happens with the 2084kv & 14t pinion.
TC3, I'm in Melbourne.
Not only did I fry the Quark, I also fried a brand new BLS Futaba Servo!! Surprisingly enough, my Spektrum Pro recevier works exactly as it did before. WTF?
I have another issue.
I was working on my mates E Revo (converted) last night & mounted a brand new MM V2, but, then remembered I had to change the settings on the ESC to remove brakes, change the punch & LVC.
I plugged it in to the USB cable & the two greens came up on the screen & into the program I went.
Altered the required settings & when I went to update it, it constantly stopped with an error code saying that the ESC wouldn't respond & failed to update.
I tried 3 different USB cables for MM's & still no luck.
Broke out another brand new MM V2 from the same batch this morning & it worked without a problem.
Has anyone had this issue?
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
