myndseye
myndseye's Avatar
09.22.2008, 02:25 AM
<> as long as you don't have your voltage so high that you are revving into your motors inefficiency rpm range, the following statement is almost always true. In a truck with two available setups, if it's geared to go the same speed with each setup, the higher voltage setup will draw less current.
