The Kira 600 sure has enough power for an Emaxx especially on 6s2p A123 (Good for 3KW peak). The bigger Kira 650 would run cooler under heavy load, but the Kira 600 should stay in check tempwise, but may be on the hotter side. I would fit the Kira 600 with the kontronik KK600 heatsink as showed in the MBX5T pic.
The Jive ESC has no feature to set a current limit.
