Sorb3t
09.24.2008, 06:42 PM
url]http://www.rc-monster.com/proddetail.php?prod=medusa3670&cat=20....on[/url] 4s, go with the 2200kv...on 5s go with the 1600kv...The 5s set up will be the more efficient set up...If you are running 6s...even better!
What would happen if I ran the 1600kv motor on 4s, or the 2200kv motor on 5s?
I would say that a neu 1515 1y would be your best bet to get temps down. The feigaos run hot no matter what gearing you run. The are ok bashing motors, but for a heavy truck and racing they will not cut it....
Similarly, what would happen if I bought a Neu 1515 1Y and then wanted to go 5s, would I need the other Neu motor 2D or 2.5D or something?
Thanks for the help!
