Originally Posted by Happywing
So far, no luck. I can't get the connector off the board. The heatsink is in such good contact with the connector that I can't get it hot enough. the heatsink just sucks away the heat. I've about had it with this controller. Who's found a better alternative?
Choose a Drill Bit that will fit the diameter of the wire, then drill through the center of the connector. (CAREFULLY)
Then remove what's left of the connector with a Dremel tool.
This is what I've been thinking of doing. I haven't crossed the line and voided the warranty yet though. Hmmmm...........to do or not to do?
