When you say normal 17mm hexes, do you know of some manufactured specifically for the crt.5 stub axles???
I thought someone said they used the new era rs4mt 17mm hexes (but maybe that was for an LS10 conversion)...
If there are some simple 17mm hex adaptors out there that wont have play, I dont mind not having the additional offset (as long as they will run without rubbing the chassis)
