Dafni
Dafni's Avatar
11.01.2005, 05:10 PM
Looks good. This will be an awesome RC!
You can insulate the plugs with shrink tube. This will also keep the plugs in place.
A "L" heatsink should fit perfectly on your 1940, I thought.
As for size of bolts to mount it, just measure the mount, heatsink-base, and add 3mm for the motor. My bet is a 8 or 9mm screw would do. Or get a 10 mm and add a washer.
Edit: I just realized where you are worried about shortening! The back plate!
See, the Lehner has a secure endbell, not a glued one. You can simply loose this rear bar on the heatsink!
