Originally Posted by MetalMan
If you are going to run mod1 you may need to switch to MGT spur gears (46, 49, 52t). All you have to do is bore out 3 of the slipper peg holes to 5mm, and then the gear will be a nice tight fit on the slipper hub.
Don't forget to use a 5x10mm bearing as the Stock 5x11 slipper bearing will not fit the mgt spur. I find that even with the 5x10 bearing I must use a reamer to open up the center hole slightly...
