auto2
09.29.2008, 06:33 PM
just to check the wires for the switch? did you jump them by the switch ? maybe one of them broke by the esc?
rootar
rootar's Avatar
09.29.2008, 09:25 PM
well after i got the esc out and began to take it apart, i decided to pull the wire loom off and what do ya know when i pulled the wire loom off guess what came with it the negative switch wire i cant really get to it good with out taking it apart but once i get it soldered back on maybe ill be in business agian, should i just solder the wire back on and leave the tail for the switch (about 3 inches of the black and red wire) or shoul i just wack that off and put a tiny little direct jumper wire between the two terminals on the board?
lets keep the fingers crossed and hope this is what it is and that i didnt just pull it off when i was trying to get the pesky loom off.
