George16
Supermaxx
George16's Avatar
09.29.2008, 08:21 PM
That's the same email I got. I think they need to be more specific as to what are causing the problems unless they are not certain.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
phatmonk
RC carbon junkie
phatmonk's Avatar
09.29.2008, 08:27 PM
What are these "setups" they are speaking of.It does seem alot are 6s cell counts.But then some are 4s etc.
TruckBasher
TruckBasher's Avatar
09.29.2008, 08:34 PM
Well, I am also interested about those setup..maybe once the finish making the fix they would tell us...
IMHO, I still think its more of the design of MMM rather than setup...well at least for my case...my second MMM is still running unmodded..out-of-the-box...same truck same battery but this time I used UBEC like when I was running the truck on MM....
Hopefully CC will tell us or will completely fix it...once V3 will be release I will have reason to send my 2 MMM...save on shipping them both...
E-Slayer direct drive to diff
e-mikey
09.29.2008, 10:23 PM
After thinking about it, it would be insanely creepy and probably illegal to post a .wav file of a telephone recording.
Where I'm from is a 2 party, assumed state which means both parties need to know they are being recorded, unless it's assumed (police/fire.) I'm not sure this was the case when I was on the phone.
I'm sorry for even suggesting I would post a call.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.29.2008, 10:29 PM
Anybody seen a photo of the new case?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
e-mikey
09.29.2008, 10:50 PM
lol... I can't be the only one he told that the beeps may have caused a "minor issue"
DRIFT_BUGGY
09.29.2008, 10:51 PM
I wouldn't mind if the new MMM case didn't have a Fan cover. Just cut that part of the case off and screw a fan into the headsink instead similar to the Losi 1/8 ESC
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
09.29.2008, 11:17 PM
That MMM looks familiar.
Christophe
09.30.2008, 03:45 AM
Hello, any news about a potential V3 serie?
It seems there is problems when we use the BEC of the controller, with Ubec or RX pack it seems it doesn't burn.
DRIFT_BUGGY
09.30.2008, 03:53 AM
Yeah, can't remember where I got it from
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Dafni
Dafni's Avatar
09.30.2008, 04:47 AM
Oh, here we go again!
Told ya guys before, we can't stop here, THIS IS BAT COUNTRY!
(sorry, couldn't resist... another member has a Hunter Tompson avatar too)
as for your question, sadly there have been cases where UBEC equipped MMM died... but fortunately very few so far.
Christophe
09.30.2008, 04:52 AM
Hello,
Yes it's a bad country, too much bat !! Here we go .
Thanks for your reply about the burnt MMM even with Ubec, I wasn't 100% sure ... There is a little problem with this MMM, I think it's a good thing for me to have a delayed order ...I'll probably wait a litlle before placing my order, I let C/C some months to reply to my e mails ....
GT35R
09.30.2008, 09:18 AM
Haha thats rich - "the setups are damaging the controller"
more like the controller is damaging peoples setups!
My setup has worked with 4 different ESC's, the MMM was the only one that
didn't like it.
At least they have sent me a $0 invoice for my modded failed MMM, so I'll call it even
for the servos the MMM took with it.
coolrunnings
09.30.2008, 09:59 AM
I think 6s set ups are damaging the controller....everyone still thinks its ok to run 6s neu 1515 1y combo's with the thing. Everyone wants the worls fastest e revo and only wants to spend 150.00 for their esc...lol.
09.30.2008, 10:09 AM
I personally think there are a few issues:
1: People running 6s setups AND high KV motors AND geared too high. That combination pulls too much current on startup.
2: The BEC is too prone to problems. While they're designing it, they should also add some catastrophic failure circuit to the BEC output. Would still cause the ESC to fail, but at least your servo(s) and receiver would be saved.
3: Case is a poor design. IC/parts contact the bottom, throttle/switch wires could be chafed on the case, and (on V2) the bullet connectors are much too close to the heatsink. Also, if they insist on leaving the fan, allow it to be replaced without having to take the case apart.
