Go Back   RC-Monster Forums > Support Forums > Novak
10.01.2008, 02:34 PM
Ciao come siete? - benvenuto a RCM!
That is a VERY fast 5000kv motor you will need to go as small as possible 9T.... Novak 5109
In reality I'm not sure that it will survive 4s Lipo and 70k RPM for very long. Even novak say "is best used for short, high-speed runs"
I would be looking to get something with a lower KV.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.2941176470588233
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 9
Total Voltage: 14.8
Motor KV: 5000
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 4.44 : 1
Total Ratio: 29.01961 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 74000 RPM
Vehicle Speed: 44 mph (70.68 km/h)
Estimated Adjusted Speed: 41 mph (67 km/h) - 6% loss
Effective KV Value: 5000
Quello è un motore che MOLTO veloce 5000kv dovrete andare piccolo quanto 9T possibile…. Novak 5109 In realtà I' m. non sure che sopravvivrà a 4s Lipo e a 70k RPM per molto lungamente. Anche il novak dice il " è il meglio usato in breve, runs" ad alta velocità; Stavo osservando per ottenere qualcosa con un chilovolt più basso.
