lutach
lutach's Avatar
10.02.2008, 09:45 AM
Thanks Luciano. Check your pm.
I didn't see anything for 4 pole motors on the instructions so I decided to set it to low instead of leaving it on the middle setting .
Sent you an e-mail with my address. I posted what the timing should be with a 4 pole motor in the thread. Low timing is basically for 2 pole motors. All my 4 pole Y winding motors I run middle timing on them. The Neu D winds motor would be ok with low timing. Outrunners and most of the 6 pole inrunners do ok with high timing. I usually run low Kv 6 pole motors with middle timing without any problems. What usually happens, is the MCU doesn't process the data fast enough with the 4 and higher pole motor with low timing and you get a phase that burns like that.
