George16
Supermaxx
George16's Avatar
10.02.2008, 11:26 PM
You can change the settings to your liking, but I reather have the timing set to middle for the Y wound 4 pole motors. You should also see how many AMPs your pulling just to make sure it's not exceeding the 180A burst.
I don't have an Eagletree to check on the amps . But yes, I'll keep the timing on the middle setting this time around.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
