Unsullied_Spy
Unsullied_Spy's Avatar
10.03.2008, 09:54 AM
I am a little scared when i read this, because i have order a 1512, 1.5d for my slash (it is light than a Muggy) and i will run it with TP 3s, 5000mAh, i hop that this motor will not pull too much amps from my pack
I wouldn't worry about it. That motor can actually move a 1/8th buggy OK with proper gearing. By my estimates, as long as your battery can put out 110 amps it'll be fine. That lipo is a 25C pack, right? If so, it should work without a problem. A 20C 5000 mAH lipo would work, but it would get strained a bit under heavy loads (proper gearing and it probably wouldn't be an issue).
