MetalMan
MetalMan's Avatar
10.03.2008, 01:20 PM
The fact that the pack you are looking at is only 15C doesn't mean it isn't capable. The "C" rate is only half the story - 15C at 8000mah is 120amps - which is way more than enough. 3s in a Rustler geared for under 50mph should work well with even 70amps continuous (ie 3500mah 20C). You would just get a crapload of runtime.
