10.04.2008, 08:03 AM
Ohms law covers this...
Power = current X current x resistance
Power = current X voltage
So for constant a power output ( amps x volts) the loss is the square of the current. Hence to raise the power by a factor of 2 - raising the voltage by a factor of 2 keeps the loss constant - raising the raising current by a factor of 2 to achieve the same result raises the losses by a factor of 4 - i.e 4 times as much heat!
This is why power lines are at 100,000 volts....
Clippy
10.04.2008, 08:49 AM
So for constant a power output ( amps x volts) the loss is the square of the current. Hence to raise the power by a factor of 2 - raising the voltage by a factor of 2 keeps the loss constant - raising the current raising the raising current by a factor of two raises the losses by a factor of 4.
UMMM....yep thanks Arct1k.
"This amperage thing is just another thing to confuse me."
That didn't help but I think there might have been some important words missing in your main paragraph or double ups? Not sure sorry mate....
Cheers anyway, but I still don't get it
