Proline DR , Paintjob Idea Was Taken From Someone On the Traxxas Forums
Vxl System
Custom Dyed Black Chassis.
Maxamps 8000 11.1v Lipo Tekno Battery Straps
Revo Gtr Shocks (Custom Longer Ends For The Rear) With Jato Springs/ Bad Horsie Shock Socks
Proline 8 Shooter Beadlocks Sitting On Hpi Geolanders
500k diff fluid
Trx Alum Bellcrank / Ti-Rods
jr xr2i radio
Looks great! Definitely the best looking slash I have seen. Couple more blue accents to go with the servo and ESC and it will be perfect in my opinion.
Wow!! love it!. I'll try to post some pics of mines this week. How your shock setup work???
For me i've kept the stock shock, with 45 oil on the rear and 55 on the front. Traxxxas red TMaxx spring for the rear and stock rear slash spring for the front.
I've install a custom sway bar (Hyper 7 one) on the front.
My wheel/tires combo is Traxxas nitro rustler wheel with proline badlans tire.
I've the RCM/FLM diff case with a Neu 1512 1.5d on 3s thunder power 5000mAh pack.
I've put the traxxas red aloy bellcrank with all red aloy turnbuckle.
Wich rod end have you put on the rear revo shock???
shocks work nice a bit stiffer than stock i might have to drill out the shock piston holes a bit other than that it works good, yea the mustang scoots also a ticket dispenser.... 90 in a 55 5 pts later :[ frownie face rod ends on shocks were turnbuckle ends with rubber inside the hone there really strong.
thats sweet man, my new Hardcorr body should be here anyday, i was honestly planning on ALMOST the exact same paint scheme, except blue and white instead of your black and yellow, with a little extra design over the hood aswell......as our series rules go we can only use the stock shocks with aluminum caps, we also have to use the stock tires and wheels but i really like yours and i really like that black chassis, which body is that?
it does but you can open it up, 500k is so think i don't come out.
I hear that somes guys use 7000 and last for 2-3 month in the diffs, so 500K will probably stay for a year
I'll try oil too in mine to the place of the grease, for a beter diff action
