JaySki
JaySki's Avatar
10.06.2008, 01:55 PM
Originally Posted by Emaxx_Quebec View Post
I tried to calibrate my MMM ( first one, V2).
When I plugged the batts, (4s2p4000)i saw a very little wite smoke comming out near the del light.
I unplug evrythingright away.
When I tried again, there was no tone at all from the MMM BUT seem to calibrate correctly exept sending signal to the motor. ( it's suppose to vibrate a little, but notting!!! When i pull the trigger, green and yellow del light, full brake, red and yellow light, neutral, yellow only, BUT the motor is not spinning at all !!!
Brand new 9xl motor.
Is there a way to verify if a brushless motor is still good like when we connect + and - to a 9v to a brushed motor to see if he's still spinning?
Thanks
That, I would say, is the tell tale sign of a Burnt BEC circuit.
