10.07.2008, 12:05 AM
It appears that the c50 gearbox models have a 6mm shaft. Otherwise the endbell still appearrs to be screwed on like the nongearbox models. Even if the screw pattern is different, it would not be difficult to drill and tap the front cover.
Specs: http://www.hackerbrushless.com/motor...spx?series=C50
10.07.2008, 10:36 PM
No, I *think* that the exiting shaft from the gearbox is 6mm, while the actual motor shaft remains 5mm.
10.07.2008, 10:44 PM
Don't *think* to hard, you may hurt yourself... Don't see you doing too well on the reading comprehension part of the ACT either...
"C50XL Acro Geardrive Motors are available in 3.7:1 or 6.7:1 reduction with 8mm threaded shaft and Prop Adapter"
6mm shaft is for the input of the gearbox, thus it is the motor shaft diameter. Many motor mfgs do this with geared motors.
Also thse shafts are hardened steel, so no machining. You will be stuck with 6mm bore pinions...
10.07.2008, 11:00 PM
Sorry, I got a concussion today. I'm not really on top of things right now. And I wish I was joking.
10.07.2008, 11:03 PM
That sucks, I got one of those once and have no memories from 8yrs old and back, Not joking here. Cars hit hard when you are on a bicycle...
I hope you feel better, just take it easy. Sorry to give you a hard time, just found it funny.
10.07.2008, 11:23 PM
Damn! Any other injuries? I hear that if you go to sleep with a concussion you can fall into a coma. Sounds like BS (baloney sausage, as my cross country coach says) but I don't know. I guess I'll take a "risk" and sleep, though. I'll be okay, but I'm really light-headed and it's kind of hard to type, so pardon my errors.
10.07.2008, 11:30 PM
Screwed my lower and mid back, lost the first 8 years of my life, and damaged my bike!
You should be ok, what did you do to get a concussion...
