glassdoctor
TEAM FUSION
glassdoctor's Avatar
10.07.2008, 09:26 AM
Try setting the throttle end points to 100 and also the brake sub trim needs to be maxed out or the MMM wont see it as full brake/reverse.
Look over all the throttle trim and end point settings and you will get it.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
