Mamba Max LVC CutOff
jacko
Hump-E-Revo
Mamba Max LVC CutOff - 10.10.2008, 02:11 PM
Does anyone know the maximum workable cut-off voltage of the MM's LVC? I have two 2s2p 8000mah batts wired in series to run on a MM and I'm not sure what's the recommended cut-off voltage value so I don't run my batts dead.
E-Revo Basher:
- MM w/ Fan & CC BEC & 700HO (20/68)
- 2 2s2p SPC 8000mAh
- Maximizer 1/2" Offset w/ Badlands
MR4TC CF/Alum Drifter:
- Novak XBR 8.5 Motor & ESC
- 6-Cell 3300 NiMH
- ABS Tires
brushlessboy16
brushlessboy16's Avatar
10.10.2008, 02:13 PM
cutoff would be between 12-13v for what would be 4s. the maximum is 20v iirc
jacko
Hump-E-Revo
10.14.2008, 02:21 AM
I set it to 13.2V before and now put it up a notch to 13.6V for 4S and it looks like that's the bravest setting i dare go.
E-Revo Basher:
- 6-Cell 3300 NiMH
- ABS Tires
