Finnster
KillaHurtz
Finnster's Avatar
10.11.2008, 10:25 PM
If you really want max speed, Id go the 1Y on 5S or the 2.5D on 6S (its fine on the MMM, really)
45 is more than plenty for the track, so a 1Y on 4S, a 2.5D on 5S or a 3D on 6S are all good choices. The 3D would be the coolest, but a 2.5D is really good two. Can't go wrong either way.
Also, take the time to learn to solder. Its really quite easy and really needed if you will be using elecs. Its like not knowing how to clean an air filter and running nitro.
10.12.2008, 12:10 AM
Everybody wants to go fast. High voltage and a lower kv motor that is geared up will perform better for longer at higher speed. Temps will be better that way. 55mph will be a handful, that is for sure.
portyansky
10.12.2008, 08:13 AM
Just make sure you get resin solder.
TraininModeRacr
10.12.2008, 09:04 AM
Wow, first thread I've ever started and first posts ever and I am getting replys!
As for the electri-clutch... whats it do? Prolly tames the torque a bit huh?
with the clutch what are my gearing options? A LOT of people swear by the 1Y and with its great KV I am curious what I can work with on gearing. By shooting for 50-55 am I gonna lose a lot of punch?
