JThiessen
JThiessen's Avatar
10.13.2008, 12:01 AM
I'm about 50 percent done with this swap over. I got a "standard" 3.3 from one of the members here. Everything is moving over quite easily - 'cept I've run into a little issue with the center shafts. I have the 3906 tranny with the Gmaxx single speed conversion. On my 2.5, I think I used two of the 2.5Revo front shafts (whichever one was the longest). I ordered the half shaft set for a new E-Revo, but they are the same dia as the driveshafts, and at least going to the rear, they wont clear the fwd corner of the bulkhead. What did you guys use for the centers?
BTW, I also picked up an E-Revo chassis to play with. Just from an initial look, there seems to be decent possibilities for aftermarket battery trays.
