Originally Posted by George16
So which one is better suited for a revo conversion on 4S?
36-70-2000
or
36-70-1600
If you're only going to run 4s the 2000 would probably be better. If you plan to step up to 5s or 6s go with the 1600.
I've already got a pre-order in for the 70mm and 80mm 2000 KV motors, 70mm for my Hyper and 80mm for my Muggy. I'm a little unsure about using Medusas instead of a Neu, I was sooo happy with my 1515 I don't know about the lower rating of the Medusas. I guess I'll find out.
I like longer motors because they generate more torque, the more torque you have the less work the motor has to do. The problem is that they also draw more amps so you have to balance the length, KV, your batteries voltage, the weight of the vehicle, etc. It drives me nuts trying to decide which motor I want.
