Semi Pro
Semi Pro's Avatar
10.16.2008, 06:04 PM
Actually, if I went with the 13 lb. thrust option it could lift off vertically.
Think of it like that experiment you may have done in high school physics. Hang two weights over a pully, one 9 lb. weight and one 13 lb. weight.
If the fan can lift it vertically then it will definitely not have trouble moving it horizintally.
thats a good point
i was just thinking about how fighter jets make 10x their weight in thrust but then they also travle much faster than a gtp
how fast shoud it be able to go?
are u planning on putting a screen over the fan to protect it from debris
