Originally Posted by Sammus
Wow losi diffs use traction ramps? I think this is losi's secret tech exposed...they should be worth much more...
For anyone who wants to know the actual difference: fioroni tractive is a clutch type torque sensing diff that uses special traction ramps (a heap of different ramp angles are available for different tuning) which activate a kind of clutch between the spider gears and the drive shaft (the internal gears rest on an angled cutout, so as the diff unloads the pinions climb the ramps and locks the diff more and more)
The ofna style torsen diffs are geared torque sensing diffs, which use a weird worm gear drive setup. The disadvatage is that both driveshafts need to be loaded for it to work properly - if one wheel lifts the diff just unloads.
An advantage of uing torque sensing diffs over speed sensing (ie the viscous diff we're all used to) is that there is n to no power loss in a torsen diff (unlike a viscous), and they last a lot longer.
That is not right. Torsen diffs 'sense' when there is a torque load on an axle and increase the coupling of the driveshafts to keep a certain maximum torque difference between the wheels, you still get the inside wheel spinning at higher rpm.. If you bind one wheel of a viscous diff and go wot, your other wheel will spin fast. With torsen I think this (potentially, depending on the setup) is impossible, it will lock once the difference is big enough (its all relative to the torque on the axles, which i think will only let the ratio of loaded and unloaded wheel rpm be so much). I think torsen diffs often only are limited slip under throttle, and open off throttle - something you cant acheive with a viscous diff.
Ryu James: Perhaps you didnt reassmble them properly after taking them apart before using them?
Here is the exploded view of the Tractive diff: you can see it is very different to a standard diff
http://www.twf8.ws/new/tech/options/...e_IV_mugen.pdf
edit: just d/l the losi 8ight manual to look at its diff. They are the normal sealed oil kind.
thanks for the clarification Sammus. its not that i reassembled them wrong, i was just saying they look exactly the same as the losi diffs. maybe i am not seeing the difference. i am glad i am wrong though. makes not feel so bad about spending $750 on diffs but i have yet to drive a stock losi so i dont know what kind of performance advantage the fioroni diffs might be giving me. so are there different components to the Fioroni diffs or just the ramp angle on that one part makes the difference? maybe tonight i will tear down the center diff of both the fioroni and the losi and take some pics to post.
ok, so i am an idiot.
maybe when i spend some time in a setup without the upgrades i can truly apprciate the fioroni diffs that i have. as for my turn in, i obviously need to adjust my suspension/sway bar to achieve desired results. that is another topic i could use some help with. anyway, here is a great article on the Fioroni diffs and what they do.
"Fioroni's Tractive IV torque reactive differentials are the most advanced differentials ever made for 1/8th off road vehicles and can be effectively used on buggies, truggies, oval cars, and rally (IGT) cars. An innovator in high end upgrade parts for radio control models, Fioroni's Tractive IV differentials are the fourth installment of 'torque sensing' differentials, following the international title winning Japan, Hyper, and Storm Traction differentials.
Tractive IV differentials are a type of limited slip/torque sensing differentials. They operate much the same as full scale Salisbury differentials, but on a smaller scale, and perhaps arguably in more severe conditions. The locking is enabled by internal ramps which act like a wedge, with the throttle and brake torque being applied to it. The rate of lock is in direct reaction and in direct proportion to the torque input- the more torque, the harder it locks. The angles of the ramps can be changed with optional parts to achieve various handling characteristics.
Compared to an 'open' or standard bevel gear differential commonly found in off road buggies and trucks, Fioroni's differentials work quite differently, both on and off throttle. While an open differential sends power to the tire(s) with the least amount of resistance (think front inside truggy tire ballooning coming out of a corner), the Tractive IV differentials balance the power output more evenly. Instead of thickening differential fluids or changing suspension settings to compensate for the loss of power, which often results in an equally negative effect elsewhere on the track, you can send more power to the wheels without a drastic change in overall handling. By adding lock, the wheel with the least resistance is less likely to spin, which means more power is being put down, resulting in faster acceleration.
Off throttle, the Tractive IV differential will act somewhat like an ABS system (Anti Lock Brakes). Your car will be more stable under braking and if you choose, you can increase the rear brake bias, often shortening brake distance. With today's improved suspension geometry and constantly improving tires, these differentials can be used effectively to lower your lap times. Another direct result is longer tire life. The less your tires spin, the longer they will last.
Fioroni's Tractive IV differentials are a powerful tuning option, not a savior to a poorly assembled and incorrectly setup vehicle. It is recommended to use the front differential first, followed by both the center and rear. By using all 3 there will be a noticeable change to the handling of the car as well as an obvious decrease in tire wear. The differentials can be used on a variety of surfaces from loose dirt to clean pavement. Make sure to try them in practice first and make chassis adjustments as needed before using them in racing conditions.
The standard ramp angles are 120 for Front differentials, 80 for center differentials, and 40 for rear differentials. Optional 60 and 100 degree ramps are available for your tuning pleasure. For optimum performance, it is recommended to clean and re-grease the differential after each weekend of racing, with a maximum of 3 races in between cleaning and re-greasing. Although not necessary, it is suggested to re-install the internal components in the exact position, and allow a short break-in time for new or freshly rebuilt differentials. Do not use any grease or oil except for the one included with your differential and available as a spare part (TRC-020). The differentials can be fully rebuilt and a full line of spare parts is available. You can further complement your car's drivetrain with Fioroni LIC range of lightweight axles, hubs, and gears, available for most popular racing buggies and truggies.
Fioroni Tractive IV differentials, like all Fioroni product, are designed and made in Italy using only the highest quality materials and process. Beware of knockoff 'torsen' differentials. They often work poorly and are made of sub par materials. Fioroni Option Team parts are tested and used by IFMAR World Championship winning drivers. Tractive IV differentials are available for the following cars and their compatibles: Associated RC8, GS Cl-1, Kyosho 777, Losi 8, Mugen MBX5R, and XRAY 808 (available June 2008)."
