10.18.2008, 02:32 PM
I think losi needs to take the xxx cr buggy and put a small stadium truck body on it. Then they can create the much needed 11th scale stadium truck class. Make it a ready to run with a brushless setup too. At 600 bucks they will fly off the shelf.
Plus a 2wd lst based truck would be cool, call it the "Mega Donut". Make it single speed with no reverse, good for 30mph top speed.
Also they need to put a coaxial blade cx style setup n the mlst, making it a true do-anything vehicle. They will have to re-engineer the drive system for the blades to be as weak as the mlst diffs though...
A carpet only version of the xxx-t would be cool. And a dual .05 motor xxx-nt would be a hot seller too.
Are you kidding or are you serious? I can't really tell with you, you're so convincing yet those ideas/prices are outrageous.
Mega Donut.
