Hippie's GTP Project
10.19.2008, 08:31 PM
Originally Posted by
rchippie
Thank you
Does anyone know if they make a plastic spur to replace the steel one on GTP ?.
If it is the single speed, the ofna 51t plastic spur bolts right on.
Alot of Savage parts for sale!!!
Find all posts by lincpimp
2
rchippie
10.19.2008, 08:54 PM
Yes it is a single speed james . Thats great news . I was going to ask if this could be moddedd to fit ? .
http://www3.towerhobbies.com/cgi-bin...?&I=LXHSY8&P=7
REAL MEN RUN BRUSHLESS
rchippie
Find all posts by rchippie
3
What's_nitro?
Soldermaster Extraordinaire
10.20.2008, 03:16 AM
rchippie
Probably. You could use the steel spur as a template for the four holes.
What's_nitro?
Find all posts by What's_nitro?
4
10.20.2008, 09:06 AM
Do they make a plastic spur for the hyper ST centre differential?
Find all posts by BL_RV0
5
10.20.2008, 09:27 AM
If it is the std plastic case non-spider design, a kyosho plastic spur will work. They only come in 44 and 46t though, but should work since the st has 11/43 diff ratio.
6
10.20.2008, 09:29 AM
Here is a link to the gear that will fit the gtp:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBM16&P=7
7
rchippie
10.20.2008, 10:51 AM
James that gear would be the easyest to use since there would be no modding needed . I was just trying to use the stock ratio if possible .
rchippie
Hybrid Mode
Switch to Threaded Mode
