TexasSP
Something, anything, nothing
TexasSP's Avatar
10.19.2008, 11:56 PM
Did you check the bearings RPM rating first? I would make sure they are rated well above 60k RPM's. Other than that it should be straight forward to replace them. I doubt you will see any performance increase though as Neu using pretty much top notch materials as it is.
www.cubicle101.com
FG101C
10.20.2008, 12:01 AM
I'm just thinking for when they will need to be replaced. So far they're ok, I figure they are probably ceramics from the factory anyway, or something just as good.
I just clean them and put a drop of oil in them before each race day, now if I could just finish a main, today I was 2.5 minutes short of 20 mins. I think it's mostly in my trigger finger.
