- i sawed off the motorbullets very very carefully
- ream them so that there is no contact with the heatsink anymore
- removed the whole hardcase and small fan.
- put a bigger foam under the esc and a 40*40*20mm fan (feed in by the batteries not the bec) on the heastsink
- soldered the motorwires directly on the board
- disable the esc bec
- and shrunk the whole thing with a big heat shrink tube.
some pics. i still haven't used it yet. however programming with the castle link functioned ok.
i'll use a receiver battery or a UBEC. not sure yet.
bye
rhylsadar
