e-mike
e-mike's Avatar
10.24.2008, 05:07 PM
however...we need to open the case just to deplace the wire an prevent an fan issue???
D8t on juice!!
10.24.2008, 05:16 PM
I would at least remove the lower case and try to move the fan wire over to fit in the notch I circled a few pics back... That would be my only suggestion for the best performance...
10.24.2008, 05:13 PM
Finalized pics of the fan wiring... It is a snug fit with the negative terminal but it all fits and the shrink continues down the wire pst the pcb edge to protect it.
I hope this works, I am sick of opening MMM cases. I will say they are easy to open after the 10th time...
George16
Supermaxx
George16's Avatar
10.24.2008, 08:45 PM
Ok, had a good look at the lower case and noticed that there is a small notch near the clearanced area where the fan/switch wires exit the case. I can only assume it is where the fan wires should go to avoid them being pinched between the lower case lip and the pcb.
So I figured out another place to route the wire that will require minimal case mods and will allow the use of some shrink to protect the wire. The wire is usually brought down between the two caps on the negative bullet side. If you add shrink to the wire it is almost impossible to get it to fit there.
If you move the wire over and place it outside the case slightly it will clear the caps and can go down between the case and the negative bullet. I would put some shrink on the wire and make a small notch in the case next to the bullet. Then there is enough of the wire left to plug it into the pcb and shape the wire so that it fits in the notch that is made into the lower case ledge (shown in the pic above)
Visual aids...
Thanks for the pics. That seems to be the best alternate route for the fan wires.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
New case
DLS II
New case - 10.24.2008, 10:27 PM
What's the procedure for getting a new case? I have a brand new V2 that I've updated the firmware on and I'd like to have a V3 case. Don
sikeston34m
sikeston34m's Avatar
10.24.2008, 10:40 PM
This is what Bernie Wolfard had to say in response to that very same question.
"Just call or email us with your request. Our email address and phone number are on our website: www.castlecreations.com."
I just emailed and requested a V3 case for my V2, and they responded quickly and said they would send me one out.
I hope this helps.
CRTIM
10.24.2008, 10:45 PM
i just went to there website http://www.castlecreations.com/ and click on the email address at the bottom and requested a v3 case ....be sure to leave your mailing address. The next day they responded by letting me know they were shipping me one out
mxracer
10.24.2008, 10:57 PM
i still think the fan plug is a weak idea.(they really need to improve on it ) when i get my replacements i will just run the fan from the aux port on the receiver. the problem with the switching fan idea is that if u bring your truck in after a few laps and the fan is not running , it could be either
1. not over 150deg
2. the fan/wiring is busted and not working..
so most would assume its not over 150deg and keep on driving but if the fan is not working due to damage , then you will just keep driving until smoke comes out . (exactly what happened to one of my esc's) ..and those fans are not very tough at all.
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
10.25.2008, 01:21 AM
1. not over 150deg
If you are going thru all the trouble to attach the wire to the rec, why not just add the shrink like I did and re-route the wire. The fan plug on the pcb has plenty of clearance with the bottom case now, unless the pcb breaks in half the fan plug will not touch. The fan wire is the only problem I see now. All of mine will be modded like this, and I expect them to work fine.
123revo
10.24.2008, 09:40 PM
yeah...now this is getting a bit muddy..
the user is required to open the esc case and place the innards into the new case? under normal circumstances this would void the warranty for almost any product..wth?
and now fan wires are being damaged during assembly/shipment? can you say IPC standards?
this is really getting a bit too much now that the user has to mod it to make it work reliably regardless if they want to or not.
...perplexed...
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.24.2008, 09:43 PM
So is there still a sticker covering the bottom of the case?
DRIFT_BUGGY
10.24.2008, 10:48 PM
Did you send the email to info@castlecreations.com ? I sent one 2 days ago and still haven't heard back. Not sure if I sent it to the right email
CRTIM
10.24.2008, 10:52 PM
yes ,thats the one...did you check your junk mail file ??
plaviblue
plaviblue's Avatar
10.24.2008, 10:53 PM
Just got my 2-v3's (no.5&6) in the mail today. Lets see if they make it to sunday.
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
BlackedOutREVO
10.25.2008, 01:12 PM
So this is still an issue. Ohh well, honestly as long as the speedo works, I cant complain. For the price, and everything about the MMM. Its worth it (to me)
Nice to see they kept the bullet plugs!
