Pdelcast
Pdelcast's Avatar
10.24.2008, 05:23 PM
Originally Posted by Dagger Thrasher View Post
It sounds to me like the fan control must've partly been a hardware addition, otherwise V1s would have had it when running the same firmware. IMO, it's no big deal; I guess there's a *slightly* higher chance of a fan faliure with a V1, but at the same time, it should keep things a tad cooler too. Doesn't bother me.
We had to add a transistor to allow the processor to control the fan -- but the temperature at which the fan turns on is controlled directly by software.
It is set at about 150 degrees F, which is about 65C. The hardware is good to about 120C, so the fan comes on WAY before the temperature limits on the controller are hit.
Patrick del Castillo
President, Principle Engineer
e-mike
e-mike's Avatar
10.24.2008, 05:28 PM
good to knowand pdelcast i can't send you a pm...??why
D8t on juice!!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.24.2008, 06:37 PM
120C What temp does the MMM shutdown? (if it has that option)
Pdelcast
Pdelcast's Avatar
10.25.2008, 12:12 PM
It shuts down at around 120C. If it does shut down, it waits until the internal temp drops below 70C before it will rearm.
V3 updates
transtalon
V3 updates - 10.25.2008, 05:37 PM
I received my MMM V3 yesterday. I am running a Hyper 7 buggy with a 4S Poly rc 6K and a 20 tooth pinion. I ran it on two charges already and it seem
like it's working out real nice. The Hyper 7 is so stable at high speed and handles pretty good also, doesn't even flip over unless it goes in the grass and slid. I am pretty happy so far, I am also using the internal BEC from MMM.
Do you think the ESC can handle a 25 tooth pinion for more topend. I'm running a Neu 1515 1.5 D and it is a monster for it's size. Thanks for trying to please your customers Castle and any comment on the pinion gear will be nice. I don't wanna burnup my MMM, so any comment will be appreciated. Thanks again Castle Creation for doing the right thing.
