molak
10.26.2008, 11:15 PM
The one that produces the power your need at the higher efficiency..
It´s a complex matter... It depends on how you gear it, the effieciency "curve" of your motor, the efficiency of your ESC and how you drive it.
Batteries are your power source, a limited one, so each time your slipper slips or your wheels spins, you are shortening your run time..
pd: the efficiency curve should be a 3d map rpm, torque and volts.
