hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.27.2008, 04:20 AM
Originally Posted by asheck View Post
.IMO 6s puts the motor to high in the RPM range for everyday bashing.For occasional speed runs it should do good on 6s, but 50000 rpms seem to high for every day bashing.Since I have no Neu,are they happy in the 50000 rpm range?Actually it would seem to me like 5s would probably do good,maybe the sweet spot?But still a little high?
I have now had a chance to run my e-revo (MMM w Tekno Neu 1515/1Y) on the same track using two different voltage set-ups.
Set-up 1 TRC 4s 15c 8000 mah Geared 58/24 (41mph)
Set-up 2 Zippy 6s 25-30c 4800mAh Geared 20/65 (46mph)
Everything ran cooler on the 6s set-up. BUT!...to be fair...A couple things. It is too fast for the track(both set-ups were really) so i may gear both down a bit more next time I go. When i ran the 6s set-up, i had added some mudguards which eliminated ALOT of rotating weight that got added to the driveshafts while running on 4s. Also, it was a cooler day out when I ran on 6s (overcast).
Temps;
4s (MMMv2)= ESC 140-155 / Motor 135-158 / batteries 110-118
6s (MMMv3)= ESC*** 110-118 / Motor 100-112 / batteries 90-95
I am starting to get the impression that these motors like to run in the high 40k's to low 50k's without alot of heat buildup if geared correctly.
*** something kinda weird happened with my MMMV3. The fan is coming on at around 110F. I checked the temp throughout the day and it never got hotter than 118 in the hottest spot i could find on it, yet the fan wouldnt shut off. Wondering if maybe I have a bad transistor. *shrug*
________________________________ next
Originally Posted by BlackedOutREVO View Post
I want the motor thats in the E revo BL, I think the black motor looks better. How will I go about this? Is castle going to sell the combo both ways, or is there going to be the green for castle, and if I want the black version it comes from traxxas? Or how is it going to work?
Thanks!
...according to Patrick, Castle will sell both a Green and a Black motor;
http://www.rc-monster.com/forum/show...307#post224307
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
