Unsullied_Spy
Unsullied_Spy's Avatar
10.26.2008, 10:30 PM
NO it'lll not hold up.....never
+1, I annihilated a diff with a 1515 1.5D on 4s so a 1521 is out of the question. I'd go with a 1515 1.5Y on 6s maximum (the E-Revo diffs are supposed to be tougher than the ones I had, hopefully that's true). The Tranny is pretty tough, but the bottom gear is plastic and a 1521 could very possibly destroy that gear.
RBMike
RBMike's Avatar
10.26.2008, 10:31 PM
I put more the an hour & a half of track time on the V3 today. Worked perfectly. Fan was on a couple of times when I came in but went off usually before I could get the body off. Looking good so far.
Todays V3 set-up:
MBX6-RCPD conversion (MBX5)
Medusa 36-60 2K
5S A123
I did open it & put some shrink tube on the fan wires cut a little off the inside lip of the bottom cover to give the wire a little more room.
tuclai
tuclai's Avatar
10.26.2008, 11:37 PM
So I took my MMM v3 out yesterday and today. Before the v3, I had three MMM v2 and all of them died on the same day after about going through half of my NEU 5000 lipo!
I got my MMM v3 back on Friday and yesterday took it out just doing speed passes on the dirt. Ran for about 20 minutes and LVC kicked in. Temps were good througout. Motor= 135, battery 127, ESC 117.
I then took it out to the tracks earlier today, and through two batteries everything was good. Motor= 140, battery 130, ESC 120 On the third battery after LVC kicked and I temped. Motor 140, battery 130, ESC 155!!!!. Wondering how all of a sudden the ESC was at 155, then I noticed the fan was not on.
So Looked into it and usually when you first turn on the ESC the fan is suppose to spin then go off. Well it never spins. The ESC worked, just hot and fan was not spinning. So I took off the case thinking maybe the fan connector came off, however it was still plugged nice and tight. So I disconnected the fan from the board and plugged the fan directly into a receiver battery and the fan doesnt come on. Verified there is 6.5 volts, however fan not turnning on. Looks like the fan is dead. Oh well, at least the ESC still works, at least there is progress there.
My other two MMM v3 is supposed to be delivered tomorrow, so one will be the replacement for my truggy and the other will be going into my buggy. Now I just dont what I should do with the unit with broken fan. Should I just find a replacement fan and run external wires directly to the receiver? What do you guys think?
14 months and 22 cars and 2 helis later.....
http://good-times.webshots.com/album/562025697XGWJlX
RBMike
RBMike's Avatar
10.27.2008, 10:44 AM
Fans Die, It's a consumable, like Fuel or glow plugs use to be.
Edumakated
10.27.2008, 12:00 PM
I am going to run my fan off the receiver. I just haven't had any luck with the Castle Fans.
10.27.2008, 01:15 PM
I think castle will supply a replacement fan is you contact them, though it dpends whether you want another fan that *may* not last very long, or whether you want to source your own 25x25mm fan from elsewhere.
Pdelcast
Pdelcast's Avatar
10.27.2008, 01:33 PM
Yeah, just give Tech Support a call, and they'll get you a replacement out.
Patrick del Castillo
President, Principle Engineer
Thanx CC
1truckerdan
1truckerdan's Avatar
Thanx CC - 10.28.2008, 12:46 AM
All I can say is that I LOVE MY MMMI can do backflips from a standing start on 6sI have already run 3 sets (2x2s2p reedy 5000mah)of batteries on it and 2x 3s1p 4500 flightpowers. I am running a KB-45 (1600kv) with 25/54 gearing. Temps on the motor have never gotten over 150... MMM 130 ...and batts never got over 100, thats on grass ,dirt and pavement.I still haven't been able to give it wot( not enough runway)
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
10.28.2008, 01:33 AM
yeah just shoot an email to castle creations...i emailed them and Joe Ford got back to me ASAP and 3 days later I got 3 fans and I only asked for 2...great/fast service.....by the way I ran my V1 and V2 without the CC BEC and with the update and both are working perfectly!!!!.....Now to fix my rear diff case and rear hub carriers after hitting a jump at 45+ and not landing on my wheels.......Novak/MGM/Losi/Tekin who?????
....There it goes.....I probably just jinxed everyone and their MMM's.....my bad :)
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
Mmm V3
transtalon
Mmm V3 - 10.28.2008, 06:13 PM
I was wondering if I could run the Monster on the LST2 with the 1527 1D 2300 kv and a 6S? Do you think the ESC will be able to supply the current that the bigger Neumotor? Thanks, I just wanted to keep my V3 running and not overworked it beyond what is's rated.
jnev
jnev's Avatar
10.28.2008, 06:25 PM
It is not the ESC that would get overworked, but the batteries. There are very few batteries on the market that will be able to supply the current that the motor will be asking from them. 2300KV on 6s is also asking for trouble. The RPM's will be too high to run as efficiently as possible. And honestly, the 1521 motor will be plenty to push around an LST2.
Mmm
transtalon
Mmm - 10.28.2008, 08:08 PM
I have a 2.5" extended Lst2 and the batteries are the new 8K 25c 6S from Maxamp. I do have a Neu Energy 5S 5k lipo that I could try it out. also my
Lst2 is quite heavy (17+) with all the batts and motor and also a big Genesis wheels and tire combo. I ran it before with a different controller and a 5S 8k batts but found out my batts were dying out on me. I figure with the 6S it should be just crazy fun. Also my Lst2 is anything but a stock, trans FOC +9 pinion gear and it still pulls with no problem. I also ran it with the 1515 1.5D and a 5S and it hauls my truck with Muggy tires real good. It is uncontrollably
fast at high speed but I recently made some changes on my Muggyfied LSt2 with some control arm limiter and would like to test it.
tc3_racer_001
tc3_racer_001's Avatar
10.28.2008, 08:14 PM
get some 50C constant 10000mah lipos which weigh a few hundred grams and your set... will jsut have to wait a few more months/years before these are available!
try find the highest C rated packs you can find which arent maxamps.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
transtalon
10.28.2008, 08:54 PM
Why some bashing ? I was trying to get a reply with Castle about the MMM ESC. What I do with my setup is my business not yours. I am not a newbie with this brushless conversions. So if you have no answer to the question that I asked then it's not for you.
George16
Supermaxx
George16's Avatar
10.28.2008, 09:23 PM
Whoah, welcome to the forum .
You asked a question and you received some answers even though some of them are not what you wanted to hear.
Why don't you just e-mail CC or Pm Patrick, Bernie, or Thomas and asked them if you just wanted an answer from CC ?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
