10.29.2008, 01:44 AM
Good luck with the GTRe. I had one and thought it could do with quite a bit of work to be competent for high speed. The center brace limints battery height, mine had alot of drag in the belt setup, and the barkes just did not work well. Plus that big electronics box is kinda dumb, it would be better to have a battery tray on that side too. And you motor choice will be a bit limited due to the special 3 gear pinion with 1/8 bore. Maybe get a medusa 50mm with 1/8 shaft, but I think a larger motor would be required to run 100mph...
Sounds like an interesting project, I have only seen a few GTPe floating around, I had mine well over a year ago. It was brand new when I got it.
