Be carefull changing your lipo plugs, not to short them out. I just diconnect one wire at a time, dissconnect from old plug, slide heat shrink on wire, solder, shrink heat shrink & repeat.
I think the Hyperion Duo come with a multi adapter balance connectors so do I have to buy something else to balance a Thunderpower and JST balance connector?
Is the EC3 from e-flight and the EC5 from losi are the same?
yes you will need to buy an adaptor board which plugs into the charger for both of those. they are around $7 if i am remembering correctly. and yes, always one wire at a time!!!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
