rootar
rootar's Avatar
10.30.2008, 09:51 PM
soaking them in turpintine and them sealing them off in a ziplock bag until right beofre the race is the absolute stickiest you can get a set of tires, but you can be assured that after that race they will be worthless.
i think this helped alot the tire just feel ALOT softer i snipped half the big outter lugs off and the inside halfs of the big center lugs. the tire on the left is the grooved on obviously with the stock on the right. you can see now their are no big continous lugs to slide all over with, just lots of small lugs with room to get a bite....should work good, i never had much luck with other tires when having big gaps between the tread so thats why i left half of each lug i sniped and made it into smaller ones.
ID:	5734   Click image for larger version
